Bobkent
Jan 01, 2016Aspirant
Remote Access WNDR4500v3 via android... how?
Hi, I have enabled remote access, but looking at the instructions for the genie app both on the desktop and my android device, there are no options to select remote login? The android Genie will...
DexterJB
Jan 02, 2016NETGEAR Moderator
Hi Bobkent,
1. What is the firmware version of the router?
2. What version of the NETGEAR Genie desktop and Android app do you have installed?
Dexter
Community Team
Bobkent
Jan 03, 2016Aspirant
I am not at home at present, the router I updated 2 days before posting to the latest available. Genie version on PC 2.4.20 Android version 2.4.26.
Thanks
- BobkentJan 03, 2016Aspirant
my android screen
- DexterJBJan 04, 2016NETGEAR Moderator
Hi Bobkent,
1. What is the model number of your phone?
2. What version of Android are you using?
3. Does the issue persist on your other mobile devices (other Android, iOS)?
4. What is the operating system of the computer where you have the NETGEAR Genie installed?
5. Have you tried uninstalling and re-installing the app/program on both devices?
Dexter
Community Team
- BobkentJan 04, 2016Aspirant
HI,
1. What is the model number of your phone? Samsung Galaxy 6S Edge Plus
2. What version of Android are you using? Android 5.1.1
3. Does the issue persist on your other mobile devices (other Android, iOS)? Not got any.. can try one but not until end of week when back home.
4. What is the operating system of the computer where you have the NETGEAR Genie installed? Windows 10 64bit
5. Have you tried uninstalling and re-installing the app/program on both devices? Yes on both
Thanks
