Bobkent
Jan 01, 2016Aspirant
Remote Access WNDR4500v3 via android... how?
Hi, I have enabled remote access, but looking at the instructions for the genie app both on the desktop and my android device, there are no options to select remote login? The android Genie will...
Bobkent
Jan 10, 2016Aspirant
I have tried it on a Hudle 2 and the same.. to be honest this is an absolute joke. Possibly the issue could be wrong make of android device, wrong android version etc etc. I have the latest products, so netgear should be making sure that what they sell works with that. I am boxing it up and sending it back. It fails to meet netgears expectations, let alone mine. Thanks for your help.
- DexterJBJan 10, 2016NETGEAR Moderator
Hi @Bobkent,
I have sent you a message. Please check your inbox.
Dexter
Community Team
