Sgeorges
Jul 07, 2017Aspirant
Remote Genie for D7800 not working (unable to register)
My device is Netgear D7800 Modem/Router. (firmware:V1.0.1.20) I read through this forum and found it should support remote access thru genie. But I have trouble with enabling the remote access fr...
DexterJB
Jul 10, 2017NETGEAR Moderator
Sgeorges
Jul 12, 2017Aspirant
Hi Dexter,
Thanks for your message.
Surprisingly it started working now once I tried from another Android phone again.
All good ):
- DexterJBJul 24, 2017NETGEAR Moderator
Hi UriahSefo,
1. What is the model number and firmware version of your device?
2. Have you tried using another device?
3. Have you tried resetting the router?
4. Have you tried uninstalling and re-installing the app?
Dexter
Community Team
- DexterJBAug 03, 2017NETGEAR Moderator
Hi UriahSefo,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- SgeorgesOct 20, 2017Aspirant
Hi Dexter,
Thanks for your follow up and sorry for the delay in replying.
I have same problem again after updating the firmware to V1.0.1.22
(FYI: Recently tried firmware V1.0.1.24 , but no internet connection. Hence rolled back to V1.0.1.22).
Now router is working OK but no remote genie. Please advise. Thanks. George
