chuckdblake
Mar 07, 2020Follower
remote management
I am trying to get my NightHawk APP to connect to my router but I did not connect the APP before I left my home, I do have Remote Management turned on in the router but I still can't connect to it wi...
michaelkenward
Mar 09, 2020Guru - Experienced User
chuckdblake wrote:
....but I still can't connect to it with the APP
What hap;p;ens when you try?
Do you know the router's WAN IP address?
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find the documentation, and, if there are any, firmware versions and drivers for your hardware.
Read the section Use Remote Access.
