Papelero123
Aug 14, 2019Guide
Reset admin password in Nighthawk app
My nighthawk app stopped working and I have not been able to log back in or recover my password. Contacted Netgear support and they told me my complementary support ran out at the end of June. Ther...
michaelkenward
Aug 15, 2019Guru - Experienced User
Papelero123 wrote:
Contacted Netgear support and they told me my complementary support ran out at the end of June. Therefore for just resetting the password, they want me to sign a support contract for $189.00.
Who did you call? If it was one of those sites found with a web search, then there is a high probability that it has nothing to do with Netgear.
Many of those listings are from third-party sites that pay to appear in the search engines. They then create sites that "borrow" the Netgear logo.
Those sites will also appear if you search for other makes of hardware. Using them can be dangerous.
Netgear itself does not provide paid for support. It farms that out to GearHead Technical Support.
GearHead does not offer a support plan for $189 .
