ToryR
Aug 02, 2021Initiate
Router app doesn’t show connected devices
Hello, I have 20+ devices connected to the internet, but only 6 show in the nighthawk app. I am trying to control my daughter’s computer use but it’s impossible if I can’t see it and turn off the con...
LongFellow
Aug 08, 2021Tutor
I also have the AC1900 and this has happened to me as well. The router admin webpage and the application both indicate I only have 3 devices connected.
I've completed these steps to get to work temporarily:
1. Reset router to factor defaults.
2. Plugged in my PC only as the router booted back up and set up my network from there.
As I reconnected my devices everything started working, I could see and control my 15+ devices connected to the network. Then fast forward to not even four days later... The admin webpage AND the mobile app again indicate there are only 2 connected devices on the network. If I navigate to the access control page on the web interface, I can see the full line of devices connected but I can only block or allow the devices on the network from that page. I'd like to be able to prioritze certain devices on the network and also see which device are taking up the most bandwidth. Because of this I also don't know which band the devices are connected to 2.4ghz or 5ghz. (except for the 3 it actually shows) Does this mean I'm going have to be resetting my router 5+ times a month?? My goodness..
larryebert
Aug 09, 2021Tutor
With Nighthawk app only two devices out of 12 were showing they were connected even though all devices were in fact connected. they all were visible in the browser. the R7000 router Firmware and App versions are the latest, v1.1.11.126 and 2.10.6.1635 respectively. I have tried factory reset of the router which worked for about an hour than reverted back to the same issue. App removal and reinstall did nothing.
- FURRYe38Aug 09, 2021Guru - Experienced User
Was this working on prior version of FW by chance or has been been happening all along?
- larryebertAug 09, 2021Tutor
I think in the distant past this issue occurred sporadically. I spoke briefly with a tech and he said to try changing the Router password. I'm not keen on doing that because it requires changing it in all of the devices. And I'm seeing all the devices in the browser.
Router login or wifi password?
