ToryR
Aug 02, 2021Initiate
Router app doesn’t show connected devices
Hello, I have 20+ devices connected to the internet, but only 6 show in the nighthawk app. I am trying to control my daughter’s computer use but it’s impossible if I can’t see it and turn off the con...
jbraun
Dec 26, 2021Tutor
My router 'connected devices' used to show all devices just fine, I think it's something with the latest firmware 1.0.11.128_10.2.112.
Oddly enough, my Netgear Genie app on my Windows machine still shows all connected devices, but I'm not sure if that's actually connecting to the router to get the list. Also, on the BASIC Home page, it lists the correct number of devices (22) but when I click on the link to list it only shows 9!!! There's no rhyme or reason either, some are wifi some are hardwired.
This bug is aggravating and I hope Netgear resolves the issue soon.
Pacey_IV
Dec 28, 2021Aspirant
I have also updated the firmware to version V1.0.11.128_10.2.112 but I still have the same problem. I only see a couple of connected devices instead of the whole list.
- fumaf1Jan 02, 2022Initiate
Same with me. Using V1.0.11.128_10.2.112 which I upgraded to because I was having issues. The upgrade did the same thing.
- ccan82Jan 20, 2022Aspirant
I also used to see all devices on the app, split by how they were attached (5G, 2G, direct connection) and now I can only see 1 or 2 of 9 total. Rebooted router, deleted app and reinstalled, etc. Web version also says there are the right number of devices but in details only shows 1 (my printer). Very strange as it used to work fine over the last 2 years. NetGear did something different and they need to own it with a real solution for us rather than chasing our tails with resets, etc.
- larryebertJan 20, 2022Tutor
Try a factory reset of the router instead of reboot. Follow the router setup instructions exactly on the app after factory reset.
