GarrettMoore
Jan 01, 2019Follower
Router has security questions that I didn’t make
I recently moved into a new home and purchased an AC2400. The internet installer hooked up the router while I was at work. Everything has worked fine but i was trying to link the nighthawk app to the ...
michaelkenward
Jan 02, 2019Guru - Experienced User
There is a bug in some devices in Netgear's implementation of password recovery. You can get locked into a close loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process because you can't answer the questions.
If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
I doubt if they will have changed the password without telling you.
So I can’t login to my router settings.
What is the modem that sits in front of the router? That could cause the behaviour that you see.
