Topology
Feb 06, 2020Virtuoso
Router-Internet Speed using Nighthawk App
Using a RAX120 router (1.0.1.114) connected to a CM1200 modem (1.02.02) with 1000Mbps service from Xfinity, the Nighthawk App (2.4.18.7 on iPhone 11 Pro) reports a download speed of 400-600Mbps – whi...
Topology
Feb 07, 2020Virtuoso
Michaelkenward, perhaps I am confused? Is it not the case that the Nighthawk App reports the download speed received by the router (RAX120) directly from the modem (CM1200), because the speed test is actually running on the router itself? As a result, this measurement should be as pure and as accurate a reflection of the supplied Internet speed as is practically possible – and, therefore, should be reasonably close to 1000Mbps, which is the advertised speed from Xfinity?
P.S.: The article you referenced (Wi-Fi 4/5/6) is very informative – especially Appendix D (“Router WAN to LAN/WLAN throughput”).
