StefanoNet
Jan 24, 2016Aspirant
Router Netgear Genie DGN2200v4 Ftp to USBStorage from IPWebcam
Hi, I have a problem with my router Netgear Genie DGN2200v4. I can read and write into Usb Storage from ftp:// inside and outsode my Lan with FtpClient. When I try to write into Usb Storage from a...
- Jan 25, 2016
Hi @StefanoNet,
Are you trying to save the recording of your IP webcam to the USB storage? If you are, it may not work since the ReadySHARE feature of the router is designed for simple streaming and file transfer.
Dexter
Community Team
DexterJB
Jan 25, 2016NETGEAR Moderator
Hi @StefanoNet,
Dexter
Community Team
- StefanoNetJan 25, 2016Aspirant
Hi DexterJB,
yes, I am trying to save the recording (simple jpg files) of my IPCam to the USB storage by ftp service.
Do you know if there are Netgear's products that can solve my problem : record on Hard Disk without configuring a ftp server?
Thanks for your help.
Regards.
StefanoNet
- DexterJBJan 26, 2016NETGEAR Moderator
Hi @StefanoNet,
Your setup may require a more robust solution and may need a NAS (network attached storage). You can check if the NETGEAR ReadyNAS is an option for you. You may refer to the links below for the compatibility list of IP cameras and information on the ReadyNAS Surveillance software.
http://www.netgear.com/business/products/storage/readynas/
http://www.netgear.com/business/products/storage/readynas/readynas-surveillance.aspx
http://www.downloads.netgear.com/files/GDC/RNNVR01L-1000S/ReadyNAS_Cameras_DS_28Feb14.pdf
Dexter
Community Team
- StefanoNetJan 26, 2016Aspirant
