Jacob-clackett
Oct 20, 2021Aspirant
Router nicknames
Please see my screen shot. Does anyone know how to name these routers so on the Android Nighthawk app I can distinguish them from each other? If I click on one and then click on the image of the route...
Oct 20, 2021Guru - Experienced User
Um, unlessy your managing several same model routers which I presume you only have 1 model router, only 1 router should be seen in this list....
What device do you have NH App installed on?
What version is the NH App?
Jacob-clackett
Android version 2.12.0.1770.
I have these routers in my vacation homes and the houses are connected by point to point antennas. I live in a remote area with limited internet coverage, so I have to make my own network between houses.
- FURRYe38Oct 22, 2021Guru - Experienced User
Does the 3 vertical dots have any options?
- Jacob-clackettOct 22, 2021AspirantThe three vertical dots pulls up a menu and all that allows you to do is remove the device from your list
If you selecting on one of them and go in to the settings for the picked router, can you edit or change any with in?
I know on some routers there is the host name section seen on the routers web page. Wondering if maybe changing the host router name on the routers web page using a web browser first would maybe see a change on the NH app.
