Jacob-clackett
Oct 20, 2021Aspirant
Router nicknames
Please see my screen shot. Does anyone know how to name these routers so on the Android Nighthawk app I can distinguish them from each other? If I click on one and then click on the image of the route...
Oct 22, 2021Guru - Experienced User
Does the 3 vertical dots have any options?
Jacob-clackett
Oct 22, 2021Aspirant
The three vertical dots pulls up a menu and all that allows you to do is remove the device from your list
- FURRYe38Oct 22, 2021Guru - Experienced User
If you selecting on one of them and go in to the settings for the picked router, can you edit or change any with in?
I know on some routers there is the host name section seen on the routers web page. Wondering if maybe changing the host router name on the routers web page using a web browser first would maybe see a change on the NH app.
- Jacob-clackettOct 29, 2021Aspirant
I have messed around in the settings for quite a while. I have never been able to find anything that transfers a name to the NH App overview screen. I know where to change the router names, but that name does not seem to transfer to that screen that I need.
- Ps0653Nov 25, 2021Aspirant
Seems no one has an answer for this still. I have multiple RAX50s (not available in the dropdown - come on Netgear fix the list please) and they show up as RAX50 rather than the router name they have each been given in their specific configurations. This should be a simple chaneg to the app to have it show the router name rather than the model number -- or even both <AP Name> - <Model> i.e. Router at Home - RAX50.
