RickK726's avatar
RickK726
Follower
Nov 16, 2018
Router not connected
Recently, I have not been able to connect to my nighthawk router R9000 or my NETGEAR extender EX8000 using the nether genie or nighthawk app on my iPhone 6s I also can’t connect using my MacBook Pro with Mojave ver 10.14.1. It says my router is not connected, but if I put in the routers IP address, it will show it is connected and all my devices are connected. I checked for firmware updates, but doesn’t seem to be connecting to NETGEAR server. Any help would be greatly appreciated.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi RickK726,
    Welcome to the community!
    1. What is the firmware version of the router and the extender?
    2. Have you tried re-installing the apps?
    3. What version of the app/s do you have installed?
    4. Was working before?
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi RickK726,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
