amonynuts
Mar 18, 2022Apprentice
Running Nighthawk app re-enables 5GHz SSID Broadcast
 Nighthawk App V2.15.0.214.  Netgear RAX45-100NAS AX6 AX4300, firmware V1.0.10.110_2.0.75.     Simply running the Nighthawk App and connecting to the router re-enables SSID Broadcast on the 5GHz band....
michaelkenward
Mar 21, 2022Guru - Experienced User
This is getting weird. Someone else recently reported that they cannot get the app to control guest wifi.
Which app is this? iOS or Android?
By the way, in Windows Alt+Print Screen is easier, and more elegant, than taking photos of a screen.
amonynuts
Mar 21, 2022Apprentice
I'm running the Nighthawk app under iOS version 15.3.1 on an iPhone-8.
- michaelkenwardMar 21, 2022Guru - Experienced User
 amonynuts wrote:
 I'm running the Nighthawk app under iOS version 15.3.1 on an iPhone-8. Great. I've passed it on to the Netgear team. That's two iOS "guest wifi" issues, but complelety different results. - shadow-riderJul 24, 2022AspirantHave there been any updates to this problem? I am having the same issue with the Nighthawk app. It is re-enabling the 5GHz SSID broadcast every time sign in through the app. - FURRYe38Jul 25, 2022Guru - Experienced User
