amonynuts
Mar 18, 2022Apprentice
Running Nighthawk app re-enables 5GHz SSID Broadcast
 Nighthawk App V2.15.0.214.  Netgear RAX45-100NAS AX6 AX4300, firmware V1.0.10.110_2.0.75.     Simply running the Nighthawk App and connecting to the router re-enables SSID Broadcast on the 5GHz band....
amonynuts
Mar 21, 2022Apprentice
I'm running the Nighthawk app under iOS version 15.3.1 on an iPhone-8.
michaelkenward
Mar 21, 2022Guru - Experienced User
Great. I've passed it on to the Netgear team.
That's two iOS "guest wifi" issues, but complelety different results.
- shadow-riderJul 24, 2022AspirantHave there been any updates to this problem? I am having the same issue with the Nighthawk app. It is re-enabling the 5GHz SSID broadcast every time sign in through the app. - FURRYe38Jul 25, 2022Guru - Experienced User
