ckoslosky
Dec 20, 2022Follower
same here, nighthawk app says C6300 modem router not supported
same here, nighthawk app says C6300 modem router not supported, so is this accurate and therefore nighthawk app will not support this expensive cable modem?
1 Reply
You can use the browser to login/manage it or the genie app.
The C6300 is circa 2014. So might consider something a bit newer that supports the NH app if you feel you really need to use the NH app.
