JLRRLJ's avatar
JLRRLJ
Security Updates via Nighthawk
I am trying to update my MR60 and MS60 over Nighthawk since I won't have physical access for a month. It says they are up to date even though they are at least 2 versions behind. I entered a support call and was told they will release the updates eventually. It's been over a month. Extremely dissatisfied with Netgear. Not releasing a critical security update.
Any other way to get my system updated besides on site?
Thanks
  • plemans's avatar
    Not unless you have something/someone at the residence that could run something like team viewer. Then you could remote in and update the satellites first and then the router.
    • JLRRLJ's avatar
      JLRRLJ
      So I get another announcement that a security update is required.  Of course 2 months later its still not available over Nighthawk.
      I can no longer access the system over Nighthawk, even though I can access my thermostat, so I am assuming its hacked.
      Thanks Netgear.
      If you are going to publish a patch, publish it to all update mechanisms.  Don't make Nighthawk a second citizen.
  • FURRYe38's avatar
    FYI:
    https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
    Thanks
