kenechi06's avatar
kenechi06
Follower
Sep 25, 2023
Should I reset router ?
I recently downloaded the netgear app where I’m able to see history and set up parental controls. I tried accessing the router login but can’t get past the security questions and the only way to get past this is by doing a factory reset. Will any past history get deleted?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    History of what?
    Netgear devices remember very little.
    What Netgear device are you using?
