petrucioci
Jan 19, 2021Aspirant
software forwindows
Hello. I got this Nighthawk R7000P to changed a old 3400 N netgear and like Android have a app, is there one for windows? Like Genie was before? OR I have to use the same Genie tht i had with previo...
Christian_R
Jan 21, 2021NETGEAR Employee Retired
Hello petrucioci,
You may use the Nighthawk app to manager your Nighthawk router. To manager your router via web browser, you may visit routerlogin.net.
Christian
- petruciociJan 22, 2021AspirantWe the comunity dont apreciate that you umplug genie software. We had router loginn before. Why then you created Genie. And why you would create a software only for android and not the computer? You guys need to straight it up because you will make me go and buy another brand.
