SMUL1124
Mar 04, 2019Aspirant
SPEED TEST
GREETINGS,
MY APP DOES NOT HAVE THE " TEST SPEED" MENU LIKE THE EMAIL SHOWS...CAN I UPGRADE OR AM I MISSING SOMETHING?
michaelkenward
Mar 05, 2019Guru - Experienced User
Which app? Android? iThing?
What email?
- SMUL1124Mar 05, 2019Aspirant
THANKS FOR RESPONDING. THE APP IS ON THE APPLE IPHONE. THE EMAIL I'M REFERING TO IS AN EMAIL THAT WAS SENT WHEN I SIGNED UP.MY ROUTER IS NETGEAR R6020.
Check out these key features for your WiFi router.
Speed Test - Check the broadband speeds from your service provider
Pause the Internet - Monitor and pause WiFi on any connected deviceInternet Speed Test
Guest WiFi - Set up secure networks for guests to access your Internet
And More! LEARN MORE
- schumakuMar 05, 2019Guru - Experienced User
The Speed Test is in my understanding a part of the QoS feature, required for tuning the QoS - with the QoS feature not available on the R6020, this might be absent on both the R6020 Web UI and the Nighthawk App.
- michaelkenwardMar 05, 2019Guru - Experienced User
I have an Android app. This has a clear "Internet Speed" button. The layout is a bit different from this:
But it is there. What does your new screen show?
One way that people have fixed issues in the past is to remove the app from their device and reinstall it.
There have also been reports that the iStuff app is broken.
Yes - but what if the Nighthawk App is connected to a router not supporting QoS and the (QoS-) Speed Test?
