SMUL1124
Mar 04, 2019Aspirant
SPEED TEST
GREETINGS,
MY APP DOES NOT HAVE THE " TEST SPEED" MENU LIKE THE EMAIL SHOWS...CAN I UPGRADE OR AM I MISSING SOMETHING?
SMUL1124
Mar 05, 2019Aspirant
THANKS FOR RESPONDING. THE APP IS ON THE APPLE IPHONE. THE EMAIL I'M REFERING TO IS AN EMAIL THAT WAS SENT WHEN I SIGNED UP.MY ROUTER IS NETGEAR R6020.
michaelkenward
Mar 05, 2019Guru - Experienced User
I have an Android app. This has a clear "Internet Speed" button. The layout is a bit different from this:
But it is there. What does your new screen show?
One way that people have fixed issues in the past is to remove the app from their device and reinstall it.
There have also been reports that the iStuff app is broken.
- schumakuMar 05, 2019Guru - Experienced User
Yes - but what if the Nighthawk App is connected to a router not supporting QoS and the (QoS-) Speed Test?
- michaelkenwardMar 05, 2019Guru - Experienced User
That needs an explanation of what you are on about.
How does QoS intervene here?
If you visit the support pages for the R6020, it offers a download of the NightHawk app.
If QoS was essential, would that be there?
When I have it right, the Nighthawk routers supporting the Speed Test have this feature in the QoS Web UI area. Routers like the OP's R6020 not supporting QoS don't have a Speed Test feature in the Web UI - therefore my recursion is that if the feature is not available in the Web UI (along with the QoS controls) it's not available in the Nighthawk App, too.
Well, in a way it makes me happy that at least some of the API seem to communicate properly between the App(s) and the router 8-)
