SMUL1124
Mar 05, 2019Aspirant
SPEED TEST
GREETINGS,
MY APP DOES NOT HAVE THE " TEST SPEED" MENU LIKE THE EMAIL SHOWS...CAN I UPGRADE OR AM I MISSING SOMETHING?
michaelkenward
Mar 05, 2019Guru - Experienced User
schumaku wrote:
michaelkenward wrote:
I have an Android app. This has a clear "Internet Speed" button.
Yes - but what if the Nighthawk App is connected to a router not supporting QoS and the (QoS-) Speed Test?
That needs an explanation of what you are on about.
How does QoS intervene here?
If you visit the support pages for the R6020, it offers a download of the NightHawk app.
If QoS was essential, would that be there?
schumaku
When I have it right, the Nighthawk routers supporting the Speed Test have this feature in the QoS Web UI area. Routers like the OP's R6020 not supporting QoS don't have a Speed Test feature in the Web UI - therefore my recursion is that if the feature is not available in the Web UI (along with the QoS controls) it's not available in the Nighthawk App, too.
Well, in a way it makes me happy that at least some of the API seem to communicate properly between the App(s) and the router 8-)
- michaelkenwardMar 06, 2019Guru - Experienced User
The question was about the mobile app, in particular the iPhone app.
That does not need to do anything more clever than connecting to Speedtest.net.
- schumakuMar 06, 2019Guru - Experienced User
Again: Routers without QoS don't have the Speedtest implemented - neither on the Web UI, nor can it become magically become available on the App. How difficult is this to understand my friend?
Anfd again: The Speedtest is not impemented on the App - the Speedtest (where it's becoming available as on most Nighthawk routers) is implemented on the router. For once we're not facing an iOS Nighthapw (or Genie) App interop issue 8-)
I understand Netgear customers are confused. And I'm not protecting Netgear for doing ugly things: It's just another confusing "design" desicion - by far not the only one. Netgear is loosing this business completely, leading edge RAX80/RAX120 got features removed which used to be standard for years, from the basic el-cheepo up to the most expensive consumer Nighthawk.
