jayel49
Nov 26, 2021Aspirant
Speeds Shown In Nighthawk App
I'm confused with the WiFi Analytics section of this app. When I check my Internet speed, on the Internet Speed section it's 32.15 Mbps. When I use the Home Testing tab, on the Wifi Analytics se...
- Nov 28, 2021
jayel49 wrote:
One section is Internet Speed which registers my download speed from my ISP as 31.8 Mbps.
You didn't say what speed your ISP is supposed to deliver to you. That measurement should be about the same as that. It is a measure of how fast the data traffic is flowing on the connection.
Another section is Device Manager which shows the speed of the connection between the router and individual devices. One of the devices shows a speed of 423 Mbps.
That is telling you the speed, or Link Rate, of the connection between devices and the router.
It is not telling you anything about the speed of the traffic between those devices.
To test that, run an independent speedtest that uses the wifi connection between the device that the app is installed on.
Here's what I get between an Android tablet and a router.
The Link Rate in Device Manager is 156 Mbps
Speedtest on Nighthawk app Down Mbps 55.9 Up 13.85
Wifi test with Speedtest app Down 20.1 Up Mbps 13.3
In other words, it is like a motorway. Some cars could travel at 300 mph, faster even. But try it on a bicycle and you would be lucky to get 30 mph.
michaelkenward
Nov 28, 2021Guru - Experienced User
Internet speed section of what? The browser graphical user interface (GUI)?
What hardware are we talking about?
When I use the Home Testing tab, on the Wifi Analytics section, to test the conditions in my living room it shows a speed of 433 Mpbs.
What is this Home Testing tab? Where is this Wifi Analytics section?
Is it testing the speed of the wifi traffic between you and something else? (The speed of an unpaid and download.) Or is it testing the speed at which you device is connected to the wifi source?
Finally, how fast is your internet connection?
Which app? Nighthawk?
That tells the device to check the wired speed that the router delivers to/from your ISP.
jayel49 wrote:
Am I miss-understanding the figures?
To answer that one, all those questions boil down to two core issues. What are you measuring and how are you measuring it?
jayel49
Nov 28, 2021Aspirant
I'm using the Nighthawk App on my Samsung mobile phone. It has different sections. One section is Internet Speed which registers my download speed from my ISP as 31.8 Mbps.
My questions is how can the speed between the router and a device be greater than the speed between the router and my ISP or am I understanding the figures incorectly?
- michaelkenwardNov 28, 2021Guru - Experienced User
