mikepinkston
Dec 03, 2024Follower
start over in the Nighthawk app
I tried to use the Nighthawk app for two seperate networks, my mom's and mine. This is a disaster. How do I delete everything in the app and start over?
michaelkenward
Dec 03, 2024Guru - Experienced User
What was the problem? This should work just fine. I do it all the time.
Hard to tell how to dig you out of the hole not knowing what the problem is.
If you can see both devices/networks, you just delete the one you don't want.
Failing that uninstall the app is a regular trick.
Just another user with time on their hands.
