vangleason
Feb 17, 2016Aspirant
Static IP Address
I have a wifi IP camera that has been assigned a static IP address of 192.168.1.106, based on its MAC address. The range for the "Use Router as DHCP Server" is set to be from 192.168.1.2 to 192.168....
vangleason
The model did not seem to be uploaded in the above post.
The model is Netgear Router Model WNDR3400v2.
Thanks.
Retired_Member
Feb 17, 2016Have thought about using address reservations?
- vangleasonFeb 17, 2016Aspirant
That is the point of my post.
I am using address reservations.
I have reserved 192.168.1.106 for the IP camera.
However, this IP address is not being applied continuously to the camera by the router.
- Retired_MemberFeb 17, 2016
Static IP is Not the same as address reservations. You said static so which is it.
If you're using address reservations then don't set the range to 15 and expect 106 to be used
Please see above screenshot.
I do not understand your comment.
What should I change?
Thanks.
