Bosco78
Mar 18, 2025Aspirant
System down for maintenance
Why is Netgear still down for maintenance. It is 9:15am here in the eastern time zone. The maintenance was supposed to end at 2:30 am. PT. It is Tue. March 18.
- Mar 18, 2025
Something to and NG support about.
Or submit a bug report:https://community.netgear.com/t5/Nighthawk-App/How-to-report-a-bug-on-the-Nighthawk-App/td-p/2134684
CMolyPrairie
I can't submit a bug, because it closes the app, when I hit the dismiss notification.
"We are currently down for a scheduled maintenance. Our systems will down March 24th for 12:30a - 2:30a PT."
The grammar and date is not correct either. Is this a hack?
Mar 18, 2025Guru - Experienced User
Does the bug feature appear if you shake the phone on the notification screen?
- CMolyPrairieMar 18, 2025Aspirant
I submitted the bug that way. Great work around. And it captured the screen to submit. Thanks.
Now hopefully, with the number of people viewing, more can submit the bug.
- FURRYe38Mar 18, 2025Guru - Experienced User
Try a power off of the device then back ON as well.
Hopefully NG will get this going soon.- CMolyPrairieMar 18, 2025Aspirant
MR60
Powered all three off and back on, the app was working for a brief window and then now again the notification is back.
