Hckao
Nov 03, 2018Follower
The genie app doesn't show correct network map
The network map in the genie app doesn't reflect the actual connection. The Mac address of several devices are the same. Could anyone share how to resolve this?
schumaku
Nov 08, 2018Guru - Experienced User
One of many problems with Attached Devices, the APIs used by the Genie and Nighthawk Apps - already the "unknown" does appear to be a problem of fetching the correct information from the router, therefore the write-back does fail. This community is full with similar complaints and reports. ChristineT we can't see that Netgear engineering does take (m)any actions on a wide band of routers, and on the Apps.
Brummybloke
Nov 18, 2018Aspirant
Since the last update on my r7000 it has messed up network mapping.
Log in and it shows... do anything at all it disappears and all bar 2 devices are now unknown.
Also messes up trying to edit a device and save.. it won't save.. Then if it does it doesn't show the activity as in the selection for activity let alone any actual activity
- kaydibNov 18, 2018Aspirant
macOS High Sierra, Ver 10.13.6, Netgear Genie Ver V1.0.9.42, Nighthawk Mobile App Ver 2.2.6.16, Firmware C1.0.9.42.
After clicking on Device List to identify those connected, most identification fields are blank-Unknown shown on device type. I spent the time editing all of the fields by MAC addresses to show device name for identification purposes. Everything was great-all info was displayed. I exited, came back-everything is back to nothing. What is wrong with this feature? Will it be fixed? Very annoying.
