UserRax200
Jul 31, 2022Aspirant
The update is not working with the nighthawk app
The update is not working with the nighthawk app. First it detected the update ( 1.0.10.140.xyz), tried to apply it, failed. I rebooted the device using the reboot function, check again for firmware ...
Ivan813
Jul 31, 2022Star
For updates use a pc hardwire to the router for better results i only use the app to check if devices are connected and for the wifi analyser
UserRax200
I agree but the option to update is available within the app. It should work.
Especially that I'm not home at the moment so wired update is not an option currently.
I just wont be able to update for now.
- plemansAug 01, 2022Guru - Experienced User
What actual router do you have?
I'd highly recommend against updating with the app.
when we see corrupt firmware issues, its usually related to someone updating using the app or updating over wifi.
So you'll see us on the forums only recommending updating using a hardwired connection
- UserRax200Aug 02, 2022AspirantRax200.
Again, I understand but the option is available from the app and it was practical in my current situation.
That is why I tried it.
I am aware since a while that the app is buggy and cannot be trusted, stupidly I still tried hoping it was better.- plemansAug 02, 2022Guru - Experienced User
Seems like the app goes through phases of being decent and solid, and then total BS. And you don't really know which it is until it corrupts your devices. Which is why you won't see us recommending updating firmware on it 🙂
