guyguy
Nov 13, 2016Apprentice
Time Schedule and Parental Controls
I am trying out the Nighthawk router and I am comparing its features to Linksys and Asus routers. The router has the latest firmware version. I have a few questions about using the Nighthawk router. ...
guyguy
Nov 16, 2016Apprentice
Thanks for the response. I was able to block sites and set a time schedule on the Linksys and Asus router. Doing this task was very simple and straightforward. To followup with your answers.
1) I am not looking to block apps on the router. That would be a great feature to have but most home routers don't support it. I am looking to block www.facebook.com or www.netflix.com PER device. I want to block sites without affecting other devices. For example, I want to block www.facebook.com or www.youtube.com so that an iPod or computer doesn't have access to those sites. I don't want Mary to have access to those sites on her iPod or laptop.
2) If Mary's iPod or laptop has an IP of 192.168.0.123, I would static that number on the router and set the time schedule to whatever I want. For example, I want to give Mary from 2pm to 8pm EVERYDAY on her laptop internet access. Next, I want turn OFF the internet access at 8pm to 2pm the following day.
Again, I was able to block sites PER device without affecting any other device in the house. Also, I was able to set a time schedule PER device on both Linksys and Asus routers. It was very easy to do it on those routers and I am looking for the same easy method on the Netgear router.
DexterJB
Nov 22, 2016NETGEAR Moderator
Hi guyguy,
1. You can use the per device filtering feature on the NETGEAR Genie app/program and set the filtering level to "High" or "Custom" on the devices you would want Facebook and YouTube to be filtered on. You can check the link below.
http://kb.netgear.com/app/answers/detail/a_id/29913
2. As for setting a schedule for Internet access on specific device/s, you can follow storm1985's advice of setting up Address Reservation for the devices then block all services on a set schedule. You can check the links below.
http://kb.netgear.com/app/answers/detail/a_id/24091
http://kb.netgear.com/app/answers/detail/a_id/24055
http://kb.netgear.com/app/answers/detail/a_id/24054
Dexter
Community Team
- guyguyNov 23, 2016Apprentice
Dexter~ Thanks for the reply. Netgear has an odd way of doing things. Both Linksys and Asus use a grid to block time which to me is easier than how Netgear does it.
1. After I block a site, how long do you wait for it to take affect on the router? I thought I had tried this on my iPod and I was still able to access FB or Youtube on the browser and app. Yes, I understand that I can't block apps on a device. I just want to block sites like FB or Netflix on specific devices both laptop and iPod.
2. I will try to to set a schedule for internet access based on Storms advice.
I will try the suggestions and advice and I will post my results.
- DexterJBNov 23, 2016NETGEAR Moderator
Hi guyguy,
If you are using the per device filtering, LPC settings may take a while to take effect since the filtering is done on their servers. This is the only available solution for you to somehow block/filter sites that fit to a certain category set by OpenDNS on a per device level.
Please keep us posted on the results.
Dexter
Community Team
- guyguyNov 24, 2016Apprentice
So, I have the router up and running. I am using my iPod as the test device. The iPod is connected to the router. So, I have set the iPod to 192.168.1.101 in the reservation. I have the iPod set to HIGH for the filtering.
1. Even though I have the filter set to high, I am still able to access FB and Youtube on my iPod. I can access FB on the browser and Youtube on the app. I really would like to cover both app and browser access but I know that I can't block app access.
2. I go to Advanced and Schedule to set the time schedule. I don't want to set a time schedule for all devices. How do I specifically set a time schedule on my iPod?
3. On the network map, why does some devices go grey as if they are offline? Shouldn't devices have a constant connection?
I want to fine tune the blocks and time schedule PER device. Although the router is fast, I want to continue to use it but ONLY if I can block websites PER device and specifically set a time schedule PER device.
