guyguy
Nov 14, 2016Apprentice
Time Schedule and Parental Controls
I am trying out the Nighthawk router and I am comparing its features to Linksys and Asus routers. The router has the latest firmware version. I have a few questions about using the Nighthawk router. ...
DexterJB
Nov 22, 2016NETGEAR Moderator
Hi guyguy,
1. You can use the per device filtering feature on the NETGEAR Genie app/program and set the filtering level to "High" or "Custom" on the devices you would want Facebook and YouTube to be filtered on. You can check the link below.
http://kb.netgear.com/app/answers/detail/a_id/29913
2. As for setting a schedule for Internet access on specific device/s, you can follow storm1985's advice of setting up Address Reservation for the devices then block all services on a set schedule. You can check the links below.
http://kb.netgear.com/app/answers/detail/a_id/24091
http://kb.netgear.com/app/answers/detail/a_id/24055
http://kb.netgear.com/app/answers/detail/a_id/24054
Dexter
Community Team
guyguy
Nov 23, 2016Apprentice
Dexter~ Thanks for the reply. Netgear has an odd way of doing things. Both Linksys and Asus use a grid to block time which to me is easier than how Netgear does it.
1. After I block a site, how long do you wait for it to take affect on the router? I thought I had tried this on my iPod and I was still able to access FB or Youtube on the browser and app. Yes, I understand that I can't block apps on a device. I just want to block sites like FB or Netflix on specific devices both laptop and iPod.
2. I will try to to set a schedule for internet access based on Storms advice.
I will try the suggestions and advice and I will post my results.
