guyguy
Nov 13, 2016Apprentice
Time Schedule and Parental Controls
I am trying out the Nighthawk router and I am comparing its features to Linksys and Asus routers. The router has the latest firmware version. I have a few questions about using the Nighthawk router. ...
DexterJB
Sep 04, 2018NETGEAR Moderator
Hi etorgeson,
Welcome to the community!
You may look into the Circle feature of the R7000 instead. The links below may help in giving an overview.
http://www.netgear.com/landings/circle/
https://support.meetcircle.com/hc/en-us/sections/115000372251
https://kb.netgear.com/000038873/
Dexter
Community Team
bob1057
Sep 04, 2018Aspirant
that would be great if i didnt already own the device. I spent alot of money to redo my entire home network, firewall, ap, and 5 managed switiches just have have it downgraded. If i buy anything again, it wont be netgear.
why cant the parent controls work when the router is off and it just acts as an ap? or put the same parent controls in your firewall code?
- michaelkenwardSep 05, 2018Guru - Experienced User
I must be missing something here.
The idea of parental controls is to allow users to set rules for people on their local network.
If the router is off, there is no local network to control.
Control of devices when they are not attached to the network is really down to whatever those devices connect to.
