kremular
Nov 09, 2015Follower
Tiny unreadable Genie interface
Netgear Genie runs in a very small window and most of the text and buttons are unreadable. It is useless. My display is 3200 X 1800 but still have the same problem if I change my display settings. ...
TheEther
Nov 09, 2015Guru
Seems to be a known issue. You may have to wait for an update.
michaelkenward
Nov 10, 2015Guru - Experienced User
The move to massive resolution screens seems to have caught some coders by surprise.
Sit and wait is the best response. Not sure if Netgear is that rapid a responder to things like this.
