Yaidavila
Jul 13, 2020Follower
Trouble updating firmware
I am having trouble updating the firmware. I am unsure where to locate the password credentials.
I just purchased this and have not been able to fully set it up since the app states the firmware needs update but I get stuck there.
1 Reply
The C7000 (if that's what you have) is a modem router combo device and the firmware updates come from the isp. Not from the user.
the default login info is:
login: admin
password: password
I'd recommend following the browser based install guide as it tends to go smoother.
you can find it here:
