Hoppingrosey
Jul 30, 2017Aspirant
Turn off wifi
How can I turn off wifi on my AC1900 modem router?
Hoppingrosey
Jul 31, 2017Aspirant
Model C7100V
I read somewhere and was told I could turn the wifi off with the Netgear app, but I can't figure it out? Thanks.
michaelkenward
Jul 31, 2017Guru - Experienced User
Which Netgear app? Desktop? Android? iThing?
Sorry to keep asking questions, but Netgear likes to confuse us with its different apps.
To turn it off locally, there's a switch on the front. See page 83 of the manual:
>> Click here >> C7100V | Product | Support | NETGEAR << Click here <<
Where did you read that?
It doesn't make sense to use a wifi app to control the wifi. Once you have turned it off you can't turn it back on again because you won't be able to connect to the wifi again to turn it back on.
You can turn Guest access on and off.
- HoppingroseyJul 31, 2017AspirantThanks. I read about using the app netgear genie to turn it off and on as an answer to a question on Amazon. Anyway, I found the instruction in the manual you linked, but strangely there is no button on the unit. There is an on/off indicator light but it is not a button. Even the manual contradicts itself as it describes the face of the unit at the beginning of the manual. It says it only indicates on/off by the color light. There is no button. Thanks though for helping.
- michaelkenwardJul 31, 2017Guru - Experienced User
Hoppingrosey wrote:
There is an on/off indicator light but it is not a button.That threw me too. The manual isn't clear.
Have you tried pressing it?
Some of those buttons look like indicator lights, but they actually have two functions.
Page 84 in the manual tells you how to use the web interface to turn the wifi on/off.
