brad789
Mar 18, 2021Tutor
Unable to connect to router from Mobile App
Hello, I am using a Nighthawk R7900P router with firmware: V1.4.1.68_1.3.28 . I received this firmware as update 2-3 months ago. Post firmware upgrade, I am unable to connect to router from my iP...
- May 07, 2021
Exactly, I downloaded from Netgear Download center: https://www.netgear.com/support/product/R7900P.aspx#download and applied the update via PC.
TarugoKing
May 03, 2021Aspirant
Ha! I thought I'm the only one. Good thing I searched first.
I have the exact same issue after firmware update to V1.4.1.68_1.3.28 a couple of weeks back. Web via PC works fine but the app doesn't connect.
My router has an AP connected to it. I can connect to the AP with the app but never to the router. When I try switching to the router, I get "Device is offline" message..
Have you gotten any update on a fix so far?
- brad789May 04, 2021Tutor
My issue has been fixed, by getting the firmware downloaded from the website, then flashed the router with the downloaded file.
Once flashed, I was able to connect to my router from Netgear Nighthawk app without any issues.
- TarugoKingMay 04, 2021Aspirant
GTK but just to make sure, you meant download the same firmware and update the router via PC?
- michaelkenwardMay 06, 2021Guru - Experienced User
This section exists to ask about the Nighthawk App. It isn't the best place to get help with firmware updates.
You might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk WiFi RoutersThe firmware for the R7900P comes up there pretty often.
