brad789
Mar 18, 2021Tutor
Unable to connect to router from Mobile App
Hello, I am using a Nighthawk R7900P router with firmware: V1.4.1.68_1.3.28 . I received this firmware as update 2-3 months ago. Post firmware upgrade, I am unable to connect to router from my iP...
- May 07, 2021
Exactly, I downloaded from Netgear Download center: https://www.netgear.com/support/product/R7900P.aspx#download and applied the update via PC.
brad789
May 04, 2021Tutor
My issue has been fixed, by getting the firmware downloaded from the website, then flashed the router with the downloaded file.
Once flashed, I was able to connect to my router from Netgear Nighthawk app without any issues.
TarugoKing
May 04, 2021Aspirant
GTK but just to make sure, you meant download the same firmware and update the router via PC?
