brad789
Mar 18, 2021Tutor
Unable to connect to router from Mobile App
Hello, I am using a Nighthawk R7900P router with firmware: V1.4.1.68_1.3.28 . I received this firmware as update 2-3 months ago. Post firmware upgrade, I am unable to connect to router from my iP...
- May 07, 2021
Exactly, I downloaded from Netgear Download center: https://www.netgear.com/support/product/R7900P.aspx#download and applied the update via PC.
TarugoKing
May 04, 2021Aspirant
GTK but just to make sure, you meant download the same firmware and update the router via PC?
michaelkenward
May 06, 2021Guru - Experienced User
This section exists to ask about the Nighthawk App. It isn't the best place to get help with firmware updates.
You might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk WiFi Routers
The firmware for the R7900P comes up there pretty often.
