brad789
Mar 18, 2021Tutor
Unable to connect to router from Mobile App
 Hello,     I am using a Nighthawk R7900P router with firmware: V1.4.1.68_1.3.28 . I received this firmware as update 2-3 months ago. Post firmware upgrade, I am unable to connect to router from my iP...
- May 07, 2021
Exactly, I downloaded from Netgear Download center: https://www.netgear.com/support/product/R7900P.aspx#download and applied the update via PC.
TarugoKing
May 04, 2021Aspirant
GTK but just to make sure, you meant download the same firmware and update the router via PC?
brad789
May 07, 2021Tutor
- michaelkenwardMay 07, 2021Guru - Experienced User
That's the way to do it.
Thanks for the feedback.
For others in the same boat:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
