brad789
Mar 18, 2021Tutor
Unable to connect to router from Mobile App
 Hello,     I am using a Nighthawk R7900P router with firmware: V1.4.1.68_1.3.28 . I received this firmware as update 2-3 months ago. Post firmware upgrade, I am unable to connect to router from my iP...
- May 07, 2021
Exactly, I downloaded from Netgear Download center: https://www.netgear.com/support/product/R7900P.aspx#download and applied the update via PC.
brad789
May 07, 2021Tutor
michaelkenward
May 07, 2021Guru - Experienced User
That's the way to do it.
Thanks for the feedback.
For others in the same boat:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
