sunnyvaletweety
Jan 31, 2021Aspirant
unable to connect to router, Nighthawk X10 AD7200 Smart Wifi Router
I got this router as a gift a bit more than a year ago, now I tried to set it up, using netgear nighthawk app, but when it tried to connect to wifi, I kept getting "Unable to connect ..." There are ...
Jan 31, 2021Guru - Experienced User
what modem/gateway is it connected to?
did the wifi on/off button get hit? push and hold it for 2 seconds.
Is it just the app thats not working? does anything work if connected to it?
sunnyvaletweety
It's connected to Netgear N450 WiFi Cable Modem Router.
I tried to hold the wifi button for at least 5 secs, and saw only 60GHz led off and on.
Also tried reset it, but with no luck.
- plemansJan 31, 2021Guru - Experienced User
Have you logged into it to see if ssid broadcast was disabled?
When you factory reset, did you push and hold reset for 7-15 seconds?
Did it work prior? You put it was a gift/given toyou, maybe there was a reason?
- sunnyvaletweetyJan 31, 2021Aspirant
It's not just the app that's not working, All my devices do not detect this netgear network label at all.
If connect an CAT cable from compute to the router, it's working.
Yes, I did hold it for at least 10 secs when reset.
This gift was from a brand new box, seal is not broken at all.
is your n450 cable/ modem/router in bridge mode?
- michaelkenwardFeb 01, 2021Guru - Experienced User
N450 is not a reliable guide to model number. It is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Is it the CG3000Dv2?
If so, you are piling a router behind a router. To use the R9000, you may have to put it into AP mode.
Cable modem routers are not designed for easy conversion into "bridge mode by disabling the router bit.
How to use N450 (CG3000Dv2) as modem only, connec... - NETGEAR Communities
In AP mode you lose various features:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
