Checkers
Sep 22, 2015Aspirant
Unable to create a free OpenDNS account
I am currently trying to open a free OpenDNS account on Netgear Genie. I am using a Netgear R6100 router, and setting up the new account on Mac OS 10.10.5. My problem is after I enter my username,...
nathKent
Nov 06, 2015Aspirant
thanks. in the end i used my smartphone to create the password
tanvi09
Nov 09, 2015Aspirant
How did you able to create the account.
Can you help.
- nathKentNov 10, 2015Aspirant
Hi,
I downloaded the android app on my smartphone and were able to create an DNS account (you will nee upper case, number, lower case and special symbol).
Then back on the computer and log in the newly created account.
good luck
if you have a second hand netgear, you may also need to ask them to deregister the device from the old owner account.
