Checkers
Sep 22, 2015Aspirant
Unable to create a free OpenDNS account
I am currently trying to open a free OpenDNS account on Netgear Genie. I am using a Netgear R6100 router, and setting up the new account on Mac OS 10.10.5. My problem is after I enter my username,...
Checkers
Sep 23, 2015Aspirant
I am doing it through the Netgear Genie that I downloaded onto my Mac last night. I have not used another computer because I do not want any of this on my childrens computer. Mine is the main one, and it needs to work off of mine.
DexterJB
Sep 23, 2015NETGEAR Moderator
Hi Checkers,
It is okay for you to perform the account creation process using another computer or device since it will not treat that computer as the main computer which will have control of everything. This is for us to isolate if the issue is with the computer. Once you have successfully created your OpenDNS account, you may configure everything on your main computer.
Dexter
Community Team
- churroSep 27, 2015Initiate
I am having exactly the same issue with my ipad app as well as the netgear pc genie software, no matter what 6-20 character password I enter I get "Passwords must be 6-20 characters long" message.
