Checkers
Sep 22, 2015Aspirant
Unable to create a free OpenDNS account
I am currently trying to open a free OpenDNS account on Netgear Genie. I am using a Netgear R6100 router, and setting up the new account on Mac OS 10.10.5. My problem is after I enter my username,...
JonKemp
Oct 15, 2015Initiate
Has taken me an hour or two to create the free OpenDNS account in the Netgear Genie application on my PC.
In the end, I used 16 characters and wrote the password into Notepad and used cut-n-paste.
I suspect that problems may occur if the Genie Application is assuming a US keyboard as the "special" characters may not be "seen" the same as typed.
After 25 years in TechSupport I have learnt to avoid the use of special characters in passwords - it can be very difficult to enter them on different keyboards. And there should _always_ be an option to show what is entered as is common these days on smart phones etc.
I hope this helps other avoid this frustration.
- jon
- losflemingsOct 15, 2015Aspirant
Thanks for the tip. Finally took when I made one 17 characters long.
DexterJBif the requirements are greater than 8 characters why does it keep saying I can make a password with 8 characters?
Very frustrating
- DexterJBOct 15, 2015NETGEAR Moderator
Hi losflemings,
This is already being looked at and a fix should be in the works. We apologize for the inconvenience since this has just been recently implemented a part of improving the security feature. Rest assured, your feedback is noted.
Dexter
Community Team
