Checkers
Sep 23, 2015Aspirant
Unable to create a free OpenDNS account
I am currently trying to open a free OpenDNS account on Netgear Genie. I am using a Netgear R6100 router, and setting up the new account on Mac OS 10.10.5. My problem is after I enter my username,...
nathKent
Oct 29, 2015Aspirant
Hi, I am also unable to create a DNS account (router DGN2200V1, with latest firmare , 1.0.0.50, but i don think it has anything to do?)
thanks for your help
DexterJB
Oct 30, 2015NETGEAR Moderator
Hi nathKent,
This issue should be fixed now. Please try creating your new OpenDNS account again.
Dexter
Community Team
- nathKentOct 30, 2015Aspirant
hi, not ure if previous message was sent or not. ..
thanks for quick relky but i still can t creat a ddns account through the netgear genie app. please advice regards
- DexterJBNov 02, 2015NETGEAR Moderator
Hi nathKent,
Please make sure that the username is available. Also, make sure that the password contains an upper case, lower case, number, and special character. If all password requirements are met and it still won't proceed, try creating a password that is exactly 15 characters long.
Dexter
Community Team
- nathKentNov 06, 2015Aspirant
thanks. in the end i used my smartphone to create the password
- tanvi09Nov 10, 2015Aspirant
I can't create my account from PC and Iphone.
Can you help me to create the account Please.
Tan
How did you able to create the account.
Can you help.
- nathKentNov 10, 2015Aspirant
Hi,
I downloaded the android app on my smartphone and were able to create an DNS account (you will nee upper case, number, lower case and special symbol).
Then back on the computer and log in the newly created account.
good luck
if you have a second hand netgear, you may also need to ask them to deregister the device from the old owner account.
