larryrup
Aug 15, 2016Aspirant
Unable to log into R7000 router
Hi: Can use some help. Current situation is unable to log into router at 192.168.1.1. Although I was certain I knew the user name and password, I gave up trying and reset the router. I installate...
Retired_Member
Aug 15, 2016I would delete genie.
I would push reset until power led flashed
after it rebooted I would connect wired pc to router and restart pc
That's what I would do.
