AnyToddy
Feb 12, 2017Aspirant
Unable to login Router settings for WNDR4300v2 via Genie
Their is only one function could not be used normally shown as below.
When I want to check settings for the router(WNDR4300v2),it is always sticking to this page.
Even if I click "Cancel" and re-input the username/password and click OK again, it always goes to the warning message attached.
Could anyone cfm Genie do not support WNDR4300v2?
Thx.
You seem to be connecting over a wireless network (NETGEAR43).
Are you connected to the wifi?
It is usually easier to do that sort of thing wired.
- AnyToddyAspirant
Yes, my pc connects to router wirelessly.:manhappy:
Have you signed into the wifi before you try the genie?
Remember, the wifi password is not the same as the router password.
