Anonymous
Nov 12, 2019Unable to Register Product - Already Registered
Hi, I have recently installed the Nighthawk app and when I try to enable Remote Management it says my device is already registered with another account. I have also logged into MyNETGEAR and trie...
- Dec 27, 2019
Thanks Christian_R
Netgear support did contact me.
In my case, it appears i had registered the router under a different email address - which i picked up when Netgear support responded to me on that email address (Telling me they could not find anything wrong :smileyhappy:
I now need to manage the router remotely using one email address and use the other for everything else - which is ok.
Not sure if i can actually mark this thread as closed or solved. But that was a quick turnaround !
Kevin
Anonymous
Nov 15, 2019Hi Christian_R,
I haven't heard from customer care again - they seem to have dopped of the earth. Can you please help? I have PM'ed you my info.
Thanks heaps!
Kevin_Edwin
Dec 25, 2019Tutor
Hi all
I purchased this device in Aug 2016 and have the latest firmware.
I am trying to enable remote management - for a simple reason - the USB connected to it for some reason ocassionally does not get recognised. I need to reset/reboot and it comes back again. So i am hoping by remote management, when i am travelling, i can reboot the router to fix the issue - if it occurs.
I have the same issue of it being registered previously. I have always used the same Netgear account so cannot say i have used another account.
Would someone be able to help. Thanks
Kevin
- Christian_RDec 26, 2019NETGEAR Employee Retired
Hello Kevin_Edwin,
Thank you for taking the time to post. I can certainly assist with getting you some help. Please send me a private message with the following info.
Email Address:
Serial Number:
Thanks,
Christian
- Kevin_EdwinDec 27, 2019Tutor
Thanks Christian_R
Kevin
- Christian_RDec 31, 2019NETGEAR Employee Retired
Hi Kevin,
Happy to hear support was able to get in contacted with you. I have marked your latest response as solved :)
Have a great day!
Christian
