Retired_Member
Jul 14, 2017Unable to register router for genie remote access
I just bought this router and now I am trying to turn on remote access from Netgear genie app on iOS and Mac OS X.
From iOS version, when I toggle on for remote access, it always shows Enable failed with server error as the message.
From Mac version, I pick remote access from the dropdown then enter my email + password then after login I see a popup showing the device is not registerd, do you want to register the router. I hit ok then a router login window is showed. I enter login information then hit ok then I see the registration process failed, try again message.
I have no idea what's going on. I did turned on Turn Remote Management On.
Router Firmware Version: V1.1.0.38_1.0.1
R6700v2
Using iOS 10.3.2
Mac OS X 10.12.5
with Netgear Genie
Hi jfisher5742,
The steps to login remotely from a computer via the Genie app are similar. The link below are the steps on how to setup the Remote Login feature of the Genie app.
http://kb.netgear.com/app/answers/detail/a_id/26109
2. Here is the link to setup Remote Management.
https://kb.netgear.com/976/Enabling-your-router-s-remote-management
3. Here is the link for an overview on ReadySHARE.
http://kb.netgear.com/app/answers/detail/a_id/20391
4. You can also check pages 56 to 59 of the user manual linked below.
http://www.downloads.netgear.com/files/GDC/WNDR4300/WNDR4300v1_UM_30Oct2015.pdf
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi Retired_Member,
The Remote Management feature is different from the Remote Login feature of the NETGEAR Genie app/program. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/26255
Dexter
Community Team
- jfisher5742AspirantLink you posted Was not helpful for me. He said he is using Mac & iOS. I am too. I am having the same issues. Possibly my model of router not sure? Please elaborate on setting up remote access to router. I am trying to access my readyshare hard drive remotely.
Hi jfisher5742,
Dexter
Community Team
Hi jfisher5742,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- ShyamTTAspirantI have the same issue. I have a R7900p and I have enabled the remote management check mark on the router management web portal under advanced setup. But, from my ginie app,bit will not allow me to either register or turn on remote access. It keeps failing. I called technical support and two people could not help.
I have a R7000 in AP mode as well on the network. I am able to turn on remote access on this R7000 using the app.- DexterJBNETGEAR Moderator
Hi ShyamTT,
1. What is the firmware version of the R7900P?
2. The Remote Management feature found the router web UI is different from the Remote Login feature of the NETGEAR Genie app.
3. For the Remote Login feature of the Genie app, please check the link below for the steps on how to set it up.
4. For remote Management, check the link below for an overview.
https://kb.netgear.com/24234/How-do-I-set-up-remote-management-on-my-Nighthawk-router
Dexter
Community Team
