Streambrewer
Apr 30, 2020Initiate
Unable to see attached devices on Nighthawk App
Hi, any help would be appreciated. Up through last night, I was able to see all of my attached devices accessing my router on the Nighthawk app though the device management section of the app. Desp...
- May 08, 2020
OK, just updated the app to version 2.5.1.10 this morning and in the spirit of a festivus miracle, it seems to work again to show the devices. So far, so good.
oli1988
Apr 30, 2020Tutor
I have the same issue on my iPhone.
Netgear updated their Nighthawk app yesterday and since the update the device manager is broken on iOS.
I didn't update the app on my iPad and it works fine.
So the issue is not on your side! Juste wait for Netgear to fix it...
millerjadam
May 05, 2020Aspirant
I'm having the same issue! Did you get it resolved?
- SheWinMay 05, 2020Star
no resolution yet on the app - i guess you can log in online to routerlogin.net and block and unblock your devices...however i am not able to log in to that either - waiting on a tech to call me to fix that.....
