TVGuy
Feb 01, 2018Initiate
UP for R6900v2 not working
Just updated firmware on my R6900v2 to 1.2.0.16_1..0.1. According to release notes shown on theAdmin access, it included Interfacing with UP app. AFter installation, I downloaded and install...
michaelkenward
Feb 02, 2018Guru - Experienced User
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration. The Up App is a new way of doing things which may explain the need for a reset.
While it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
